Hello group, first time poster here but not new to woodstoves. We are replacing the hearth around an older VC Defiant stove. The stove was here when we moved in and the home was built circa 1976 so not up to code. The tiles under the stove are delaminating from the underlayment and the grout almost nonexistent.
We’re going to use ¼” concrete backer board set in mortar and tile/slate over it. And YES... extending the hearth area to code.
Question #1:
For the grouting process, is there a specific grout or grout additive that I should be looking for?
Question 2:
Will the suggested tile adhesive stand up to heat or should I lay the tile in a bed of mortar?
Question 3:
For those that have upgraded or revamped their hearth, did you go to the building inspector or have a BOCA inspection and what were the approximate costs for the inspections?
Thank you,
Jim & Kathy
![Replacing a hearth - a few questions Replacing a hearth - a few questions](https://www.hearth.com/talk/attachments/imgp0132-jpg.179301/)
Question #1:
Question 2:
Question 3:
Thank you,
Jim & Kathy
