I am replacing my roofing shingles this spring and have a 30 year old plastic skylight bubble that needs to be replaced. Problem is the skylight doesn't have a manufacturer mark on it and our contractor isn't sure where to get a replacement bubble.
I would install a modern window or skylight but the inside portion underneath the skylight has a sheetrocked 'viewport' (?) up through the ceiling to the skylight and all of that would likely need to be torn out and redone to fit a window. I'm hoping to avoid that additional expense by finding a replacement skylight bubble. The current bubble is double-paned, probably not the greatest from a heat leakage standpoint but my Jotul rocks the heat in that room so I don't care.
The one on my house is approx 24" x 48". I also have a small one on my shed, surely the same manufacturer but again no marks. That one I can just seal over as it isn't that important on the shed, but would replace it if I could find someone who makes the right size.
Any ideas of manufacturers who produce these, or produce them made to order?
Thanks for any leads!
![Replacement skylight bubbles? Replacement skylight bubbles?](https://www.hearth.com/talk/data/attachments/195/195588-5c4fcccb5c63fc489ba6a360dfa3cc86.jpg)
![Replacement skylight bubbles? Replacement skylight bubbles?](https://www.hearth.com/talk/data/attachments/195/195589-daef18c57f7d547f8d648eeef6354e4b.jpg)
