Hello all, I have a The Earth Stove model NF2000I pellet stove fireplace insert. The rope gasket around the ash drawer is shot. I need to replace it.
Can I glue on the replacement with the same high temp red silicone I used to seal the liner joints?
Also... I removed the clean out cover on the front of the firebox near the auger pot so that I could clean it out. Its a rectangular plate about 4" x 6" held on by one screw. There was a gasket behind it that crumbled and fell apart when I removed the door. What can I use as a replacement?
I was thinking about just using the red silicone but I don't think that will hold up. Where can I get gasket material and the high temp fiberglass rope for my insert? I went to the local Home Depot and to Lowes but neither of them carry fiberglass rope. I was thinking about going to the local auto parts store to try to find high temp gasket material but I want to make sure I do the correct thing.
Thanks!
Thanks!
