I finally broke down and replaced the gasket on the door of the old Dovre Aurora today, now it is so super tight I had to really force the door closed! I did it the same way that I did it years ago, used the same thick gasket that I had from years ago so it has to be the correct one, did it right on the door like last time, applied firm but gentle pressure while putting it on, loosened the door hinge so it is as loose as can be thinking I'd start loose and tighten it up but when I went to close it it didn't close, had a gap of about 3" away from the door latch! I cannot figure this out, I did it just like last time, yet this time it is so so tight, I left it closed thinking maybe it will flatten the thick gasket out overnight but I am not happy keeping it closed with that much pressure, if you see something else I am missing please fill me in!!
