A friend of mine found out that I work on wood stoves so asked me to look at his fireplace today. Sure enough the back panel was missing a big chunk and the whole back panel is about to fall apart. They have not used the fireplace for sometime as they did not know how to repair it. I know how to replace the panels but the grate seemed like it was hard to move. I did not want to break anything so did not force it. I could not see the legs on the grate because of the ashes and firewood. Do some of these grates fit in holes in the bottom panel? And is their always a top panel as this fireplace does not appear to ever had one. How can you tell if there should be a top panel?
Then I also noticed the damper had a steel bar on it for lifting the damper but the clip is broken off on tope to hold the damper closed. Sorry no picture of the damper as I did not think of it until after I left. I have no idea of what the clip should look like to weld or bolt a new one on. This might be something I will need to figure out. Thanks for any tips and help you can give.
![Replace Fireplace Panels Questions Replace Fireplace Panels Questions](https://www.hearth.com/talk/data/attachments/282/282509-d7874f0e964d220ef95e7faf86632cda.jpg)
![Replace Fireplace Panels Questions Replace Fireplace Panels Questions](https://www.hearth.com/talk/data/attachments/282/282508-a9ba9ad596ff4f4f4399aeb8e2777014.jpg)
