I have been having pin hole leaks in my DHW coil for the last couple of years. This is a non pressurized system with a 150’ coil of ¾ refrigeration tubing for my HX. My water was on the acid side around 5.2 pH, but a year ago October I installed a neutralization system and my water is now 7.1.
I had another leak last August which I thought might just be a residual weak spot, fixed it, and it was fine.
The leaks are always in the bottom third of the coil (water enters at the bottom). In the past I’ve had leaks throughout the house always in the cold water side but nothing since I installed the neutralizer.
The heat exchanger from the furnace (two 150’ coils) is made of the same material and there have been no problems in 6 years.
Last night I noticed the tank was getting high again. Is there another factor that might be causing this corrosion? I have heard that bad grounding can cause problems.
There is no real rush; I can redirect the DHW to an electric heater for the rest of the heating season. It’s just a pain to drain the tank, climb in, find the hole, cut the tubing, solder a union in, refill it and heat it back up again.![Mad :mad: :mad:](/talk/styles/default/xenforo/smileys/angry.gif)
