Repair / replace insulation behind side panels?
ohiosierra
3
Ohio
I am trying to bring back to life a vermont castings merrimack wood stove I got 2nd hand.
Inside, there are firebrick panels along the walls. Behind the firebrick panels are 1/2 inch ish thick insulation panels -- I think ceramic fiber board.
They are very old and crumbly, maybe from moisture in the past. It would take about 1 pound of bending pressure to break them.
Option A: Technically they are still holding their shape, and I could probably put them back as one option, carefully. There's a crack or two already.
Option B: I could buy replacement panels, but they are about 120 each, and I'd need 3. I'd really like to avoid this.
Option C: I could buy uncut ceramic fiber boards, and cut them to shape. This doesn't seem much cheaper, but a little.
Option D: I could use rolled ceramic fiber, which is much cheaper, same thickness, and temperature rating comparable. I'd have to carefully shape it into place.
I know the insulation is important, but in my mind as insulation it doesn't have to be absolutely OEM perfect. What would you do?
Probably option B
I'd opt for option B too.
Bought and done. Just put them in.
Option C requires care to cut. You don't wan to breath the cut fibers in either.
Thanks. I'm just already over budget on this and another $360 is a lot to swallow for insulation. What do we think about just carefully putting it back in, or what is your 2nd choice?
How thick is the insulation board? Option C can work, using ceramic insulation board, and should be around 50% less. If this route is chosen, wear a good dust mask when cutting and do this outside.
Thanks. I'll give C a try. It's 1/2 inch thickness. I did find a source about 50% cheaper and think I can cut it carefully by tracing the old one.
Shop for 1/2" ceramic insulation board on Amazon. It should end up being about 1/3d the OEM cost if cut on site.
Reactions: all night moe
