Here is the issue. I have a Whitfield Advantage II insert. It is nearly 25 years old and has run without fail, year in and year out. I have never had to do anything to it except clean it, and once when my son was about 4 (he is 22 now), put his hot wheels car in the pellets, I had to unplug the auger. Oh... I almost forgot, I had to rebuild the burn box about 12 years ago as it wore out. About a month ago, I noticed the flames getting lazy and smoke appearing inside the burn chamber. The pellets also were not burning as fast even with the flue wide open. A thorough cleaning did not fix the problem. Two nights ago it started making a dying noises and I knew the end was near.
I unhooked the stove pipe and puled the unit out so I could troubleshoot and this is what I found.
1) The noise was coming from the convection fan. I am not sure if the fan is bad or it is a result of my other findings.
2) The noise only happened when the fan speed would slow down
3) The fan only slowed down when the auger was NOT running. It appears that the fan speed dropped when the auger would cycle OFF and speed up to normal when the auger cycled ON. This was repeatable on all speed/heat settings, 1 thru 5.
4) Here is the weird part, when I manually turned the auger OFF so that it would not automatically cycle, the same pattern kept up with the power surges in the fan and it would correlate to the setting 1 thru 5 even though the auger was manually turned OFF.
At the very least, I think there is an issue with the control panel ($400 to replace), possibly the convection blower ($200 to replace) and if I am going to replace on 25 year old motor why not replace the exhaust fan (another $185 to replace) since they are probably like headlights, when one goes the other is never far behind.
So then I get to thinking, do I want to put $800 dollars into this stove or just replace it? Like I said, this old gal has been a dream. Never any problems, she just ran and ran. I spent all day today looking at replacements. I really liked the Harman Accentra ($$$$) and the Quadra-Fire Classic Bay 1200i ($$). I looked at the Breckwells but was not feeling the love (am I wrong?).
What are your thoughts? Repair? Replace? With which stove?
