What happens if you use regular spray paint on the exterior of a gas fireplace insert? Can you paint over it with a heat resistant paint or do you have to remove the regular paint first? If so, how do you remove it??
The regular paint may bubble, blister and smoke at the hottest areas of the insert. It will need to be removed before repainting with proper high-temp paint. Removal will depend on the paint. What type of "regular" paint was used?
Thanks for moving this. My daughter posted it for me and she wasn't sure how to make the post. My daughter was being helpful and repainted the black metal portion of our fireplace insert with regular spray paint while I was at work. Can it be removed with acetone?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
