Different inserts are different so it would help us if we knew what make/model insert you have.Whitefeather said:How do you remove top brick on insert to sweep the chimney? Jotul 550
CountryBoy19 said:Different inserts are different so it would help us if we knew what make/model insert you have.Whitefeather said:How do you remove top brick on insert to sweep the chimney? Jotul 550
Wow, can't believe I missed that...Whitefeather said:CountryBoy19 said:Different inserts are different so it would help us if we knew what make/model insert you have.Whitefeather said:How do you remove top brick on insert to sweep the chimney? Jotul 550
Uhm...didnt you see? Jotul 550. Dont worry about it, I figured it out. Thanks
