I pulled out the old insert today and wonder what to do now. I want to prep the chimney for an SS liner. However, there are three metal tubes to deal with. Here's what I have:
a 1966 era fireplace that measures about 35" at front of opening and 29" at rear.
a metal liner or jacket, but the fireplace floor is brick.
three metal tubes at top of fireplace that vent through brick about halfway between top of fireplace opening and mantle.
he tubes are evenly spaced at about 8, 16 and 24 inches across the opening
I want to get it ready for a freestanding stove install land liner but the tubes prevent access to the rest of the chimney. It doesn't look like I could remove the metal jacket(or heatolator unit) without a major demolish of the fireplace. The tubes must be about 3" id. and look pretty solid.
Also, as I look up into the fireplace opening I see a pretty good size lever, which I assume is the damper control. I can't budge it right yet. However, using a flashlight I can see the opening to the chimney and it doesn't look like there is any damper. In other words, I can see between the tubes and there appears to be nothing above them except the chimney.
Thanks for your replies.
