Just trying to re-gasket the top piece, where the stove pipe goes.
4 bolts, two with nuts, got them out, no problem. Other two are tapped into the cast iron. Frozen solid.
Soaking it with kroil (like pb blaster). Will try again in a few days.
Two questions:
First, is it a bad idea to use the impact driver on them (1/4" rechargable)?
Second, if I try applying heat, will a propane torch get it hot enough to make a difference?
![Removing frozen bolts on Vermont Castings Resolute- RESOLVED Removing frozen bolts on Vermont Castings Resolute- RESOLVED](https://www.hearth.com/talk/data/attachments/234/234624-c8045ac7be58e253a025415accd80fc8.jpg)
Two questions:
