The auger on my recently acquired Castle Serenity isn't feeding reliably, and I think I might have something stuck in it. When I run the auger in diagnostics mode, it moves maybe 3 degrees, waits about 1 second, moves 3 degrees, waits about 1 second etc. etc. etc. I'm assuming that is expected behavior. However, pellets only drop rarely.
I don't see any instructions in the manual for removing the auger, and the proper method doesn't seem obvious to me. I've removed the back panel, and I think I need to remove the auger motor. Which set (or sets) of fasteners do I need to remove? Attached photo show what I think are the options at hand. I also attached the exploded parts diagram.
Thanks!
![Removing Auger from Castle Serenity? Removing Auger from Castle Serenity?](https://www.hearth.com/talk/data/attachments/270/270384-bd2671bf06db45936d5f9e791d7defc6.jpg)
Thanks!
![Removing Auger from Castle Serenity? Removing Auger from Castle Serenity?](https://www.hearth.com/talk/data/attachments/270/270383-83d7f522e34d43646e88073c31ec40a0.jpg)
