- Mar 4, 2013
- 16
I have an Enviro Omega. Previously I had an Enviro Evolution and found it a little pellet fussy and I wanted something more tolerant and with better heat output. So far, the Omega is heating so much better and quicker with the same pellets.
I remote start the pellet stove hours ahead of arrival at our cottage by closing the thermostat circuit and letting the thermostat take it from there. It is often several degrees below freezing inside the cottage and much colder outside. This is when starting in advance is most important to me. The issue is that the Omega does not start on the first try. The omega seems to be worse at this than the Evolution was, although the Evolution had its failed attempts also.
I have cleaned the Low Limit Sensor and still the same. I'd like to make sure I have the ability to start it remotely when this occurs. I have the equipment to remotely open/close a circuit momentarily, permanently or for a specified duration (i.e. 5 minutes).
I see a few of ideas that I'd like to put out there:
1. Solder thin wires to the on/off switch of the control board to allow remote "pressing" of the on switch to retry the starting and get past the error 3 from the failure to start.
2. The fire is starting and burns on low for a while before shutdown, I'm thinking I can bypass the low limit switch remotely a minute before it would fail so that the stove goes into high mode and keeps running. Also, could I replace the low limit with a 110 instead of 120 without any ill effects?
3. Put a space heater behind the stove and run it for a time before attempting to restart.
4. Wire up a Hair Dryer Heater inside of the OAK to heat the incoming air to help the process.
P.s. I can tell if the stove is working from remote by the increase in temperature after 30 minutes. If the temp is going up, I know the stove is running. So I'd know if I needed to hit the start button again (have to figure out the timing)
Any suggestions? Warnings? Ideas?
