jtp10181 said:
Pellet and wood burning are two totally different beasts. Pellet vent is usually run under a positive pressure and wood is a natural draft. About the only appliances that can share a flu are b-vented gas appliances and I would not even do that. You would definitely need two liners. I'm not sure if its allowable to run two liners into the same flue though. I think maybe that's what elk was getting at.
You can NOT put more than one liner in a flue, even if they will both physically fit, it is absolutely verboten under codes :exclaim:
As also mentioned, you aren't allowed to have a wood stove in the bedroom - this has been hashed out in other threads, the reasoning seems a bit fuzzy, but thems the rules... I'm not sure if you could do a pellet stove in the BR or not, although the noise a pellet stove makes might also be an issue aside from code.
However it is worth noting that while you need a chimney type stack for a wood stove, you don't HAVE to vent a pellet stove up the chimney, indeed most people don't. Within certain limits, it is possible to vent a pellet stove through the wall, not unlike the way you can vent one of the new high efficiency gas furnaces.
Gooserider
