As a relatively new pellet insert owner, I am trying to get the fine tuning down on my Quad Sante Fe insert. Could somebody describe to me the relationship between feed rate and fan speed? I know how to adjust both, and according to my manual, when the fan speed is on high, the flames should reach out of the fire pot by about 4 inches (and if it is lower, I increase the feed rate, and if too high, lower the feed rate). Once I have that dialed in, do I leave the feed rate adjustment alone? Is there a relationship between the two like there is with the clutch and gas pedal on a car (more gas, less clutch). If I am running the stove primarily on low, should I adjust the feed rate to achieve a certain flame height? Can anybody help clarify and help me conceptualize how the two interact, and how to fine tune the stove? I hope I am not being too vague. Thanks so much, and I appreciate any help you could give.
