Regency I2500 thermostat probe location?
NateW
1
Estes Park, CO
All
Just got a Regency Cascades I2500 insert for my cavernous fireplace. I have a question about the thermostat probe, which I will also ask Regency and my dealer tomorrow. Right now the probe dead ends into the SS flue liner. I am thinking I need to drill a hole through the liner to get the probe fully into the flue. Instructions are vague as to this, but when I read the probe cleaning instructions, there is no way I could access the probe via a catalyst removal unless the probe was in the flue...
So is the probe supposed to read the external temperature of the flue liner, or the gases coming up the flue?
thanks so much
nate
  • Regency I2500 thermostat probe location?
All
thanks so much
nate
My new Regency Cascades I2500 is installed and I had the same question. I ended up just seating the probe up against the exterior of the pipe. Nate, did you get to burn last winter and did you end up installing the probe into the flue?
You need to drill a hole
Reactions: xberto
