Regency i1200 Blower
Martyman
5
Southern NH
Anyone know how to remove the blower from the i1200 unit. I watched the installer just push it on but I can't seem to pull it off. I'd like to clean the dust out.
If it is like my I2400 which I believe it is, it is held on by two slots on the upper left and right. just get one side to break free followed by the other with a little force. Should slide free
You hafta get your fingers behind one or both sides of the blower assembly
& pull it out away from the insert.
You may hafta use a flat bar to get it started.
When you re-install make sure the tabs are in the slots under
the ash lip & that the thermo-disk is in contact with the stove body.
