Hi all and thanks in advance for reading. I have a Regency HI300 installed by a "pro" last December. I've gone through a season with this thing and am now entering my second season. Although I have seasoned hardwood, split and dried myself all sitting below 20% moisture when checking a fresh spout piece this thing is just not heating the way I feel it should (struggle to get our 1300sqft first floor to 70F during a 35F Day). Its installed On external wall in a masonry chimney that has a clay liner and an un insulated stainless steel liner which was installed with the stove.
I've played with everything in terms of air/fan settings. Cutting air early/late, etc. No matter what I do the top of the stove even with the blower on low will barely break 200F. Now some other people seem to be reporting way higher temps than that with this stove. My question is whether or not this is related to the enamel finish on this stove? Does it not radiate as well as raw cast iron?
In terms of the install, he did not install a block off plate, he did however stuff some insulation to block off the old flu opening but I can't say for sure whether it was Roxul or not but I know it wasn't just standard pink insulation. I'm ot a wood stove newbie by any means, have had a family place upstate for decades with primary heat being freestanding wood stoves with everything from cheap Tractor Supply stoves to the new Hearthstone soapstone we have in there now with a catalytic converter but this is my first insert and I'm really not happy with it. I'm used to having to be in a t-shirt with a wood stove roaring but with this I'm still wearing long sleeves in the house and I just don't think that should be the case. This thing is barely doing better than the small quadrafire pellet stove which was here when we bought the house and I'm burning through wood like crazy (last year I used around 3 1/2 cords). I can get secondaries but even when those are firing real nice there's no major difference in room temp and again the surface of the top of my stove will never break 205F
I'm open to any advice in terms of what to check, suggestions or similar experience. Thanks in advance for reading.
