I have Regency CI2700. The chimney sweep in taking out the (19 in the pic) Bottom Shield (106-143) broke the heads off of the two short bolts that attach it to the (item 26 in the pic) Cast Bypass Top Plate (106-351) and another bolt head off a bolt holding up the Cast Bypass Top Plate.
I can drill the short bolts out of the Cast Bypass Top Plate and back off the remains of the the other bolt.
My question is what bolts is Regency using? And what would be recommend to hold up to the temperature of the stove? What is generally used?
Some of the bolts have dusting of rust on them which screams cheap but maybe this normal for a stove entering its 3rd season of use. Three bolts breaking is weird.
What should I replace the bolts with to hold up against the operating temperature of the stove?
Easy to get #8 bolts top out just shy of 500 degrees spec-wise. Inconel bolts top out at 1800 way beyond the safe running temp of the stove but I have no idea the cost of these or where to get them. I am not building a rocket.
I am told stainless would gall (i.e., Fuze with what it is mating together.)
I suppose after I figure out what bolts to use I could use high temp anti-seize on their threads.
I'd like to replace all the bolts.
Thank you. I appreciate it.
![Regency CI2700 Cast Bypass Top Plate Regency CI2700 Cast Bypass Top Plate](https://www.hearth.com/talk/data/attachments/316/316372-ace89081aa1ac828f09c5d28d5e19b03.jpg)
