Hi guys. I recently purchased a used Regency l3100 fireplace insert. Original owners bought the stove in 2006 so its had some use but is in great shape. First thing I did was refinish the outside of the stove with Stove Brite paint. (Looks like a brand new stove now!) Next, I replaced all the fire brick, baffles and a new secondary burn tube. My chimney is about 20' of 8"x12" clay liner. My issue is, the stove only burns hot enough to maintain 70° in my 1200sq.ft. house if I open the air control to at least 80%, and then it only last for a couple of hours before it needs reloaded. Anything less then 80% on the air control will result in low heat and no secondary flames from the burn tubes. I've read lots of reviews that say this stove easily heats homes twice the size of mine!? I'm burning split cherry that was cut in may so im guessing it's a bit on the wet side yet. Any advice would be greatly appreciated![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
