- Jun 11, 2012
- 5
I'm a big fan of Englander Stoves. Low cost, well designed and A1 excellent support. I bought an Englander 55-SHP22 pellet stove maybe a dozen years ago. A fine stove. Heated well and held up well. I used it 24/7 every winter. I had to replace the one auger and the room air blower. After moving into a slightly larger new home and leaving the old stove behind I decided to look for a new stove. I finally settled on a refurbished TimberRidge Multi Fuel Model:49-TRCPM advertised on ebay from AM FM Stoves. Stove built 05/2011. At least that is what I expected to get. Instead I was sent a 10-cpm built 08/2009. If I buy something used or refurbished I want it to be exactly as advertised. OK the 10-cpm is supposed to be the same as the 49-TRCPM. Why didn't the ad just say 10-cpm so I didn't have to worry that I was shipped the wrong stove? The build date advertised was off by almost 2 years. They could have made improvements over those 2 years. OK let's leave that behind and get to the appearance. The grass decorative insert on the one side looks great but the other side looks like the black steel wasn't touched up (it's rusted) and the silver grass looks like rust spots (ugly). Also on that side is a 3 inch
patch of rust near the back corner and some scratches where staple was used to attach the cardboard box to the pallet but missed and hit the stove. I sent Andy at AM FM Stoves an email about it and he responded that they could send out replacement parts and a can of high heat black paint used for touch up. He said he will also forward my email to Mike, customer service manager at factory. That was 14 days ago. I haven't heard a word from them and no touch up paint. Now to performance. I love the auto ignite which my old stove didn't have. I ran the stove and it just didn't seem to burn as hot as my old pellet stove did. I called Englander support and spoke to Eric. He had me go through a series of things on the control board and decided to send me a new board. I put the new board in and I can't tell a difference. I decided to run some tests to determine the high and low btu range. I started the stove and left it run through the 20 min. start up. I removed the pellets from the hopper until they just covered the auger so I would have a good starting point. I set the heat range to #1 and ran it for 1 hour. The room air blower kicked off after 12 minutes and never came back on for the rest of the hour. The stove used 1 pound of pellets on #1 for that hour= approx 8500 btu. Next I did the same test on the #9 setting and burned 3 pounds 6 ounces in an hour for an approx btu of 28700. The metal sticker on the hopper door says input rating for pellets is 4.5 lb an hour. I'm not getting close to that and I think the stove should put out more then 28700 btu. Something isn't right with this stove. The room air blower stays off on #1 setting and on #9 it should put out more heat. I'll keep updating. Jan
![Refurbished Englander 10-CPM Refurbished Englander 10-CPM](/talk/proxy.php?image=http%3A%2F%2Fi1055.photobucket.com%2Falbums%2Fs504%2Fjpm2591%2FP6070009_DCE.jpg&hash=b2417a23f3573b6f2d8ee7fd5c426306)
