Hello all,
I'm hopeful some of the experts here can help me. We have moved into a new house with a Vermont Castings Vigilant wood stove (house was built in 1982). I love the idea of having a wood stove or wood burning insert
fireplace, but I find this current alcove/surround thing huge (it is 8 feet wide and 7.5 feet high) and it intrudes into the room thanks to the raised, semi-circular hearth. (The alcove is brick that the former owners painted white; no idea if paint is heat rated).
I would like to change the surround to look something like the second picture. What I don't know is whether I should be trying to keep the current Vigilant or to replace it. It depends on stove's condition for sure, which I hope the inspection will reveal, but I'm thinking the stove might be too much for our needs (see note below). The Vigilant manual says the minimum side clearance is 14 inches if the walls are properly fireproofed. And I'm assuming something can be done to fireproof an enclosure for the stove pipe so that I can have a mantel.
I have a guy from a local chimney company coming out to inspect the Vigilant and talk to me about what might be possible with the surround. What do I need to keep in mind at this appointment? Is my idea even possible for under $10k? Are there options you think would be better than my idea? What should I consider when deciding whether to keep the old stove and redesign or get a new one?
Also, what kind of company does this sort of work? I'd like to have multiple estimates. I've been in touch with a general contractor (who is willing to do the work but freely admits he knows nothing about fireplaces--makes me nervous!) and a mason specializing in chimneys (who won't give me the time of day). Local wood stove dealers won't do it either (even if I buy a new stove from them) and haven't been able to give me names of folks who would do it. The only person who seems at all interested is this chimney repair firm which also does inspections and installations. They are coming out later this month.
More info: House used to be heated solely with wood stove and baseboard heat, but former owners installed a heat pump system with vents (those are the holes you see near the ceiling) a few years ago and said they no longer used wood stove or baseboards. Heat pump is all-electric and we're thinking of installing solar eventually to assist with energy costs. So wood stove would be mostly supplemental heat and aesthetics.
Thanks for your input!
Lina
![Redesigning my wood stove alcove Redesigning my wood stove alcove](https://www.hearth.com/talk/data/attachments/230/230279-86f6be56e7d381c2f6ed0955e18c0f84.jpg)
Lina
![Redesigning my wood stove alcove Redesigning my wood stove alcove](https://www.hearth.com/talk/data/attachments/230/230278-127a18d41f54e560c4753fbe34ec6020.jpg)
