Hi Every one...
I had a Lopi Leyden 'professionally' installed by a local dealer last October. I ran into an initial problem where there was a loose set screw on the Auger shaft and the stove subsequently wouldn't feed pellets at all. After a some cajoling, the dealer sent a service team out the next day and got the unit running....
I then had a problem where i was getting pellet jams almost daily at the top of the drop tub - an email to Travis industries suggested I remove the flap in the drop tube as they were seeing that part cause jams... This solved that problem...
HOWEVER since that time, i have had recurring auger jams in the hopper - some times as many as 3 a day, usually several per week. I can usually break away the offending pellet by hand, some times I need a screwdriver. Because this happens so frequently, I am reluctant to ever put more than half a bag of pellets in the hopper in case I have to clear a jam, I don't want to have to scoop out pellets! This all makes using of the stove quite unreliable....
I spoke with the dealer today, and they tried to brush it off as bad pellets of inconsistent length. I'm Using LG pellets, which I think I read that these are of decent quality... and looking at the bin of pellets I keep near the stove, I don't notice any that seem excessively long...
My theory is that when the stove was installed with the loose set screw, the motor was spinning around the auger shaft and that the set screw may have worn a grove in the auger shaft. When the dealer's tech came the next day and tightened the set screw, it may be tight enough to drive the shaft 90% of the time, but because of this groove the set screw is not properly binding the shaft to the motor.
Any one have any other thoughts on this? I would have assumed that the auger motor would be strong enough to break through any pellet that might protrude between the auger and the auger tube, rather than jam... (The occasional jam I can understand... but this is far to frequent for me to accept)
I've asked the dealer to come out and check on this, but they are threatening me with a service charge if it turns out to be 'user error.' I cant imagine that nearly daily (some times several time a day) auger jams is user error![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
Any help/suggestions is appreciated.
