You don't want to pay for the strongest most secure rods. A sooteater setup will work just fine for the amount of cleaning you will do.Which are the strongest, secure will not come apart or break, chimney rods and brush for my 3100 Quadrafire step-top wood stove. Cleaning from bottom to top.. Thanks
Yes much more secure. And a rotary cleaner head won't get stuck?What about using a round brush like a Rutland poly? And are snap together rods more secure than threaded ones?
Getting a brush or rod stuck in my chimney is my worst nightmare..![]()
A rotary cleaner is far more effective. And run it up into the cap and spin it there so you clean the cap as well. I clean 8 or so chimneys a day and I almost never use brushes anymore. They are harder to use and don't work as wellOK...going for SootEater , lastly I see them with white [nylon] or black [poly?] rods and understand white is more flexible, but which is stronger? I asked about Rutland circular brush n lieu of string style only because I thought it might clean more effectively..
Hey when you approach the pipe cap, how do you know that you are there and should stop?
Thanks for all the input...appreciated...
That's why I like my rod station button lock rods. Those little buttons are a painI need the pointy tool that comes with the Sooteater to depress the button to separate.
Almost all of the reviews are positive. I saw one review where that happened. Have to think user error in that case, like trying to make the rods do a 45º turn? FWIW, I just went on Amazon and looked at conventional rod kit reviews for Rutland and Midwest Hearth rods. Same complaints. I am running through a pair of 45s offset and it goes through them like butter.Hey, comments?...a lot of pictures of the Sooteater rods breaking in the review sections of various vendors for this product....an issue?
What exactly is a "...rod station button lock rod"? And a "rotary cleaner" [drill]?That's why I like my rod station button lock rods. Those little buttons are a pain
Rod station button lock rods are a professional version of a rotary cleaning system like the soot eater. They all have a head with heavy string trimmer line on it that you run with a drill. The pro versions are nicer and more durable. But a full soot eater system costs about $100. My pro rods cost about $50 per 3' rod. $75 for a basic head etc. For a homeowner cleaning once or twice a year the cheaper version is all you need.What exactly is a "...rod station button lock rod"? And a "rotary cleaner" [drill]?
Ordered SootEater yesterday...thanks for all the valuable input folks...
