New guy here. We've been in our "new" house for almost a year now. The house is approximately 150 years old, having started its life as a barn (build date unknown) and then converted to a house sometime in the 1880s. It was then added onto in fits and starts over the years, with the latest a major renovation (basically adding an entire second floor) in 1998 that also saw an update of all of the systems. Windows are good with either Andersen casement windows or quality vinyl double hungs all around. Insulation on the second floor is pretty good since it was constructed in the last 20 years, but insulation on the first floor is unknown. Heat is hydronic baseboard fed by a Buderus oil boiler. The Buderus is extremely efficient, but heating an old 2600 SF house with oil still isn't cheap.
In our previous house we heated with an Englander 28-3500 add-on furnace tied into the ductwork so I have plenty of experience with wood, but not "regular" stoves having jumped right into central heating. The new house had an old stove that the previous owner had burned anthracite coal in, but not for a few years. I'd like to replace this stove with a newer stove with a decent sized firebox and viewing window. The first floor lends itself well to wood heat as it is extremely open, about 1300 SF in all-the only areas that are behind doors are the bathroom and the laundry room. I'm hoping to mostly heat the first floor with wood and rely on the oil heat for the second floor (they are zoned separately). Here are some pictures of the current stove and layout:
The chimney appears to be in good shape-Class A stainless steel with proper height above the peak, bracing, cap, etc...just needs a good cleaning. I'd like some suggestions on a good quality stove that will supply plenty of heat to a large open space? Sticking with Englander the 30-NC comes to mind... I do realize that I will likely need more floor protection and that couch is not staying there-it was given to us but we have no use for it. Its headed to the county dump this weekend.
![Recommend a stove for this space Recommend a stove for this space](/talk/proxy.php?image=https%3A%2F%2Fi.imgur.com%2Fyhmqg9h.jpg&hash=a9769304ceb988c747906adab7c5d653)
![Recommend a stove for this space Recommend a stove for this space](/talk/proxy.php?image=https%3A%2F%2Fi.imgur.com%2Ff13Z0Ee.jpg&hash=5efdce7d7025ab97c2b86587ff101a40)
