My ski cabin is a 45 minute drive from the nearest population center and only has baseboard heat and a stove that needs new firebrick and some welding to fix sagging firebrick supports so I'm looking at new stoves. There is 13' of 6" single wall pipe rising straight to the ceiling where it connects to 6" SS insulated flue and continues another 8 feet where it goes through an upper story eave and terminates above the roofline (to code as far as I can tell). Last year when I cleaned it, it appeared to be in very good condition with no signs of wear/corrosion or other problems developing.
So I went to the closest Blaze King dealer to get a quote for the purchase/install of a Chinook 30 with fan kit and optional painted sides. They sent a guy out to provide a bid for a new stove install and a mini-split heat pump (since they are also a Daikin dealer). The Blaze King dealer is not a little mom/pop stove shop but a HVAC company that does commercial as well as residential. The bidder measured and photographed and didn't raise any red flags or concerns. I said I wanted to replace the 13' of single wall with double wall. Two weeks later I received a bid for a Mitsubishi mini-split (I asked for a LV series Daikin).
I also received a bid for the stove with the following statements that I did not anticipate:
SCOPE OF WORK
- Disconnect and remove existing freestanding wood stove in Living Room area
- Install a new freestanding wood stove in the same location
- Install the fan kit, connect to existing electrical or new outlet provided by others.
- Homeowner to make final venting connections from unit to existing stove pipe.
- Unit set up and trim included.
- New wood stoves are not meant to be attached to existing chimney/flue systems, LSM will not make final connections to existing chimney pipe. If connected to existing chimney/flue the manufacturer's warranty will be voided.
What's going on here? His e-mail provides this helpful explanation:
A homeowner can make the final connection of the vent pipe but we cannot, for liability reasons. I hope that’s not confusing.
Is that normal?
The bid came out to $4598.00 plus $200 to wire an outlet (plus tax). Maybe he didn't notice there is an outlet in the stone tile surround about where the middle of the stove will be (this is a corner install). He included an optional ash drawer (that I don't want) and he forgot to break out the price of the optional red sides (as I asked him to do).
This seems pretty expensive since they are not going to do any flue work. It sounds like they will just unbox it, assemble it and plop it where my old stove is. I can do that, I wanted a professional install!
Thoughts?
SCOPE OF WORK
Is that normal?
Thoughts?
