I'm in the process of fixing up a Defiant Encore.
An earlier thread on this stove:
https://www.hearth.com/econtent/index.php/forums/viewthread/2549/
I bought a new upper and lower fireback, gasket kit, misc odds & ends, etc. In trying to remove the old firebacks, I also removed the cat element. It looks pretty beat. Another thing to add to the list. However, there is a plate behind where the element sits. It looks like some kind of heat deflector. I can't seem to figure out the part name from the schematic in the back of the manual. It looks like its been warped and its original position was at a 75 degree angle against the inside of the stove.
Should I try and bend it back, or just get a new part. I'm not quite sure how this piece comes out.
Also, I broke three out of the the four bolts holding the firebacks on. Any good methods for extracting the bolts?
Pictures of the cat element and what seems to be "overdone" refractory material are included, as well as the back of the stove, and the inside front. The refractory material lining the inside of the reburn chamber seems to be in OK shape. Just some cracks and flaking.
Thanks much!
Thanks much!
