Back to the brain trust for some thoughts on how to run my stove pipe.
Had to use double wall since my ceiling clearance is only 9”. With the placement of the thimble due to deck/porch joists and the stove sitting in position, I’m about 4” off from centered. I have a thru the wall install so 2 90s with 15” between the thimble and I’m guessing 25+ feet of chimney pipe once I get high enough above the roof line.
Option one: Top vent- I’ve played with the one 90 degree joint I have and it looks like I could twist it around enough to add a 45 and make it work but not 100% sure until I have one in hand. Does this seem logical?
Option 2; rear vent. I’d just have to slide the stove out a few more inches and it would be a 2nd 90 right in.
Is an additional 90 going to make much difference over the zig zag angles with the top vent?
Any other advice or ideas? Thanks
![Rear Vent or will 45 work? Rear Vent or will 45 work?](https://www.hearth.com/talk/data/attachments/303/303187-f47a195d7fd1c813c46f2aa264b2eca3.jpg)
