I've had a new Ravelli RV80 for about a month. It replaced an Avalon Newport that I bought new and used for nearly 14 years, so I'm not new to the pellet stove world.
The Ravelli works fantastic for the most part and I'm happy with it except for one aspect. I'm thinking that maybe I'm overlooking something and thought I'd search out some advice before I call the installing dealer.
I'm pretty sure that it's using the wire sensor at the rear of the stove to determine room temp and raise/lower flame and fan. I have pulled that wire out and raised it so that it's not sensing the temperature 6 inches from the floor, as I'd read elsewhere on the forum.
I have the box unchecked at the stovetop console so it's not using that to sense temperature. The problem is that the actual room temperature is 18-20 degrees warmer than what the stove is set for. Right now I have the thing set for 55 degrees and the room is 73, with convection fan/pellet feed on the lowest setting of 1.
Am I overlooking something obvious or should I have the installers check it out while under warranty? Thanks!![Ravelli RV80 room temp Ravelli RV80 room temp](https://www.hearth.com/talk/data/attachments/292/292994-a671713f8309ea76190147118b0ca928.jpg)
![Ravelli RV80 room temp Ravelli RV80 room temp](https://www.hearth.com/talk/data/attachments/292/292995-c1a080f8e1c27787459874af6df7bb19.jpg)
![Ravelli RV80 room temp Ravelli RV80 room temp](https://www.hearth.com/talk/data/attachments/292/292996-0baadc0a1cb30468bcbd66a67aac4ae8.jpg)
