So I moved into a place in the middle of November that is heated by a free standing pellet stove - a Ravelli brand model RV80. Let me start by saying the stove had some issues when I moved in. The previous tenant (who I am still in contact with) said she enjoyed several years of excellent service from the pellet stove, but that recently it had begun operating strangely.
She told me that she had been unable to elevate the heat level from 1 to any of the other settings, either by the remote control or through the control panel atop the stove (both had worked before). Furthermore, all efforts to contact the manufacturer or the retailer yielded no fruit. Now, this isn't a big deal for me, I don't mind it running on the lowest setting or taking a little while to heat up the place. It heats the place fine and I'm happy.
Or I was.
A couple days ago the pellet stove started beeping at me periodically and displaying a new error message:
09 - Air Flow Meter
Now I am straight bumpuzzled as to what this could mean. The manual I looked through had a list of error messages and (after doing some translating from Italian to English) I found that two of the errors listed referred to a broken or a dirty air intake sensor... or at least I think? It's difficult to research because it's a foreign product and what little there exists in English isn't all that helpful.
I've cleaned it, both the stove and the air intake sensor, then disabled the air intake sensor by unplugging it from the circuit board (everything is still in place and in tact though). The stove still displays this error and will beep every 20 minutes or so about it. Meanwhile it still heats the place fine and appears to be working as well as it ever did. What's the deal here? Am I fiddling with the wrong part? Is there a different air flow meter? I theorized that the exhaust might be clogged somewhere and in need of cleaning but I'm not sure how to get the chimney apart to do that and before I started something so big I thought I would come and check here.
Any ideas? Suggestions? Anything I can try?
Thanks so much,
-Brian
Or I was.
09 - Air Flow Meter
Thanks so much,
-Brian
