Ravelli RV100 Startup and Programming
KOREDISH
1
California
We have settled on buying the Ravelli RV100 and it should be installed in a couple of weeks. The shop is charging for the initial programming startup as "its very complicated". I would love to hear others experience on the complexity of the startup, running daily. if you have a copy of the startup instructions, message me as I would like to read them.
Thanks,
It is not complicated.....just push a few buttons. Use the "Conversation" feature of this forum to send me a message with your email address and I can send you the instructions.
If it's as complicated as they say, you may want to reconsider buying the stove. You'll be forever at their mercy for repairs and service. A simpler stove you can fix yourself.
as a new Ravelli owner my self just this week, I did my own install and setup I can tell you it's not that hard to setup, fine tuning takes some playing around with settings but thats how you learn the stove.
Is there a way to set the rv100c chrono programming 2 change the blower level and temperature setting without having to shut the stove down between programs?
I don't think you can adjust the blower speed, that gets adjusted in-tandem with whatever Power Level you set in the chrono-thermostat. On my stove, you can change the chrono-thermostat setting while the stove is running. Why do you think you have to shut the stove down to change these??
