Hello,
I have a ravelli Francesca 2012 pellet stove.
I vacuum the pot and anything around it before every use.
I have done a full cleaning in the beginning of the season. I did not find an exact cleaning of my model but the one on YouTube seemed close enough.
I am sure the pot is clean and not clogged before I start it. I have the power set at 4 and the temp setting at 64.
After couple hrs, I get the message "do fire pot cleaning" (attached) and the stove stops dropping pellets and I am forced to shut it down.
I am not sure what to do when I get that message and my only option is to turn it off.
After it cools off, I check and the pot is not that dirty.
If there a setting somewhere to calibrate that message? I am assume it is not normal that it comes up after 2hrs of use and the only alternative it to turn it off
Any help would be much appreciated
Thank you
Thank you
