Radon Well Water Removal Systems
peakbagger
8,979
Northern NH
Anyone out there have a well water radon removal system? Looks like I have two choices, A GAC filter or an active bubbler/spray system. I also have iron in the water so hesitate to use the bubbler as it will oxidize the iron.
I am leaning towards a GAC filter and spending some bucks to swap out a toilet with a low flow unit to cut down on water usage. I do realize that GAC require maintenance but I don't use a lot of water so I will install a flow meter on the inlet and change based on flow not time.
