I was planning to install a radiant staple-up system under my living room floor. I did it under the master bath which has tile and it seems to be working fine. Our living room floor will have hardwood. I am doing this because we previously used the fireplace or the propane boiler and a coil in the plenum. With the Garn now operating I want to be able to use the lower temps that are working so well in the lower level and upper bath in the living room also. I intend it to buffer the high heat loss of 60’ of windows in this room as I either overheat the front of the house (the forced air in the house is zoned front and back) to satisfy the thermostat of the living room or leave the living room slightly cooler (operating on the kitchen thermostat) and have a comfortable atmosphere in the rest of the house.
In the thread “Theoretical†Question https://www.hearth.com/econtent/index.php/forums/viewthread/68790/ comments seem to leave me with the opinion that this is not a good choice or at least a substandard installation.
Nine years ago when I installed the staple up radiant in the joists I stapled the hepex to the sub floor, covered with foil-faced bubble wrap, and the insulated with R11 insulation. It seems to work fine but I have no way of knowing how much better it could be. (If you catch one pound bass all your life and never know there are 5 pounders you are happy! ;-)) The space below the living room is heated so any escaping energy would not be lost to the outside or earth.
Are radiant panels a necessary expense? Will I loose so many BTU’s to other areas than up through the floor to make me wish I had done things differently? Going over the top of the sub floor is not an option. Any idea how many BTU’s I will be able to get through the hardwood floor?
Please direct me in a direction if you think I should be reading more information before making my decision. I will gladly read any information or articles.
