Uummmmm?
I know it's only one zero but it makes quite a difference. One place says 400 sq ft and another says 4000? Which is correct? It would make a taddy bit of a difference in my response.
RE antifreeze.
Boiler antifreeze (Propylene Glycol) is non toxic and actually breaks down quite easily when exposed to air. The approved method for disposal is to dilute is and pour it down the drain. Ingestion of any normal amount will not cause any ill effects except lubricating your digestive system VERY well....if you get what I mean.
Regular or automotive antifreeze (Ethylene Glycol) is a completely different animal and should never be used in a boiler system. As you all probably know, it is highly toxic and does not degrade very well. It must always be disposed of correctly at a hazardous water facility and will kill cats that drink it nearly instantly. Do not use automotive antifreeze in a boiler. Naughty Naughty
![shock !!! !!!](/talk/styles/default/xenforo/smileys/shock.gif)
That being said, using the following parameters, this is what you're looking at for antifreeze and total system volume.
1. I figured you'll probably have a maximum of 10 gallons of fluid in the manifold and miscellaneous piping.
2. You'll have 4,000 feet of 1/2" tube in that slab, assuming 4,000 is the size of the building and not 400.
3. Your maximum fluid temperature will be limited to 120* and your fill temperature will be roughly 60*.
4. A 20% solution of antifreeze should be all you'd ever need where you are located so that's what I designed for.
5. I assumed that there is no major elevation difference between the fill point and the slab.
So. Your total sealed system volume will be 48.4 gallons with 38.44 residing in the tubing itself. A 20% solution requires 9.7 gallons of glycol. That should cost you about $140-160. You'll need a tank with an expansion capability of 1.8 gallons. Another $100 or so.
Make sure you use a good cleaner in the sealed part of the system before you fill with antifreeze.
Probably worth the peace of mind.
