32*40 pole barn -(3) 200ft 1/2" pex loops - energy king wood boiler
I'll need to get the exact model but ekb40 sounds familiar. A bit older but works well. I do not have ceilings in yet and I believe that may be an issue keeping things warm in my shop.
1) my switch, to turn off the blower and turn on the circulation or water pump, at its lowest settings is about 130 for the blower and 100-120 for the water pump. At least when they kick on or off.
That being said Ive gotten mixed information on the heat at which I want the water to be when going through the loops. Some have said about 100 degrees is good, others say 160-180 is fine.
Thought process being 100 degree water enters loops and comes back say 90 degrees as it shouldn't drop that much. So the pad would be kept at 90+ degrees correct? How does that translate to air temp? Heat rises. I have plastic over my peak vent and overhang vents. It helps until I can get a ceiling in, but I understand a lot of heat will rise to the truss area.
2) I plan on running a loop to my furnace in my home, and a loop through my driveway when I get it poured.
Driveway loop not an issue, but furnace loop...at what temp do I want this?
3) if I need water to be at 100 or less when entering my loops - I'm assuming I'll need a different temp switch? If so what am I looking for?
