Can someone point me toward a resources for calculating whether this stone, in and of itself, would be a sufficient hearth pad?
TIA
TIA
Thanks.Webmaster said:In general, any such stone would have very little R value.
1 inch of slate is shown about about R=.1 - or 1/10 of one....effectively nothing at all.
It would be fine for a stove or hearth extension which was only there to retard sparks - some stoves call for only this (like ceramic tile 1/4").....but these are usually stoves that are very high on Pedestals. etc...
You can get a better idea by looking at these pics:nshif said:...
/unless you are in an alcove you just need non combustable floor. Id still cut up the subfloor and replace with Duroc
Thanks for your help.nshif said:Its not that much cost or that much extra work and youll be able to sleep better at night knowing everything is above whats necessary.
Marty said:Does vertical heigth above a combustable have any bearing an the clearance for code purposes?
Hearth to floor.nshif said:Marty said:Does vertical heigth above a combustable have any bearing an the clearance for code purposes?
Do you mean height of stove bottom to floor or height of hearth to floor?
