I've got a Newmac Multi-fuel furnace... It burns wood, oil, and coal. Model CL86G-96G. I just called the Stove company and apparently, they've gone out of business after U.S. stove company bought them out. I need to replace the fire brick in my wood/coal chamber. It actually looks very simple to do by just removing the bracket and then placing the firebrick inside and then affixing the bracket back on top of the brick.
So the question I have is some of the YouTube videos that I watch for different stoves or furnaces just show people placing the brick inside without using any type of stove cement. Should I use something in between the fire bricks? Does anybody have any suggestions?
When I called the U.S. stove company they said that the fire bricks used were made with pumice and rated at 2000 degrees Fahrenheit.
They're 2 1/2 X 4 1/2 x9 inches needing at least 20 full bricks and 6 split bricks dimensions at 1 1/4 x 4 1/2x 9 inches.
Does anyone have any fire brick suggestions that I could get it from like Tractor Supply, Rutland, etc.... along with whether or not I really need an adhesive to put in between them?
Thank you in advance to anyone who can give me some advice on this.
David B.
David B.
![[Hearth.com] Quick Question on Fire bricks... [Hearth.com] Quick Question on Fire bricks...](https://www.hearth.com/talk/data/attachments/316/316066-454dac49d6977c5f2b9b323e40847901.jpg?hash=01dlekWG13)
