I spent past winter learning to operate a Lopi Med Flush insert. A work in progress, as I had to unlearn 55 years of experience with conventional wood stoves.
One issue I have is getting quick hot heat from a cold box in the morning. I get a fire started and flames filling the box quickly enough, but the blowers do not start till the thermostat reaches the preset temperature. Depending on the amount, quality of kindling and the placement this takes about 15-20 minutes. More kindling might hurry the process, but I have a limited supply, do not want to waste it. Since the box is full of flame, I would like some of that heat blown out.
The sensor for the thermostat is in the low right corner next to the controls? Building my fire in that corner, rather than the left side as I tend to do could speed up the progress? I am placing wood in E-W pattern.
An extreme measure might be to rewire the fans with a direct lead and a 2 way switch to effect a manual over ride, (after warranty expires). This could have been done by the manufacturer in the first place. Anyone here attempt this?
I am new to this forum, any suggestions, tips would be most welcome.
