Hey all, long time lurker, first time caller (errr.. poster) ![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I recently picked up a used P68 which I'm now in the planning stages for a self-install in the basement. I could use a second set of eyes from the pellet gurus on my plans and parts purchase. The stove itself is super clean and in great shape, but I'm in need of some new venting. I've been doing some reading here and I see you guys like pellet vent pro, from what I can see this seems like the best route for me. I'm in an unfinished/unheated yet insulated basement in a new, fairly airtight home. The plan as it stands right now is to install the mighty P68 into an alcove (where the foundation bumps out for the void beneath my propane fireplace (builders grade... junk) in the first story directly above. Alcove is 44" wide, 24" deep.
The basement, which I do plan on finishing is roughly 1200 sq ft in total. I'd guess roughly 600-700 of that will be finished space in the end. Rest of the house above is 2800 sq ft, two stories, open concept. The stove will be prominently displayed in the main area of the basement/living area, possibly on a raised hearth and surrounded by a stone veneer, floor to ceiling, maybe look something like this.
Where I think I want the stove, from the very back edge of the stove body (right at the gap where the hopper begins) I'm about 10" on each side to the foundation walls where each corner turns in for the bump-out. So it's really just the hopper that is tucked into the alcove. I'm measuring about 18" on the backside of stove where I'd need to put a short horizontal run, and a clean-out Tee before going vertical. I'm below grade until I get to most of the way up that concrete knee wall, which is about 48", floor to ceiling is 8 feet. I'll stop short of the ceiling by 8-10" before going out through the wall. On the outside I'm about 5' above some river rock, no other clearance or code issues outside that I can see per the Harman install guide.
Anyway, I need to pull the trigger on the venting and order up some pellets real soon. I'd really like some input on what I'm planning on picking up so I don't make any rookie moves as this is my first go round with a pellet stove. Here's what I'm looking at purchasing. Listing the parts in order from the stove outwards since I don't have a visual of this just yet, hopefully this is clear enough. My thinking is I use all black PVP inside, so it matches the stove and switch to the normal galvanized/silver outside to match the thimble and end cap. I've yet to track down what I should be using to connect the OAK, any suggestions on what I should use here?
Parts listed are mostly from https://s2.img-b.com/ventingdirect....t/230483/duravent-4pvp-48a-specsheet-2837.pdf
3PVP-ADHB - Harman adapter
3PVP-06B - 6" pipe run horizontal (between adapter and tee)
3PVP-TB1 - Tee & Cap
3PVP-60B - 60" vertical (between Tee and Elbow)
3PVP-WSA - Couple of straps to secure the 60" run to the inside wall
3PVP-E90B - Elbow
3PVP-24 - 24" horizontal run through the 2x6 wall
3PVP-HC2 - Termination end cap
1-00-677177 - Harman Direct Vent Wall Pass Through and air connection
Some 3" flexible pipe for OAK.... TBD
4 Tons of Cleanfire Pacific Softwood from woodpellets.com... currently $324 per ton + delivery
UPS/Surge protection, likely an APC 750 for safe shutdown![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
I'll work on getting some pics next.
Thanks guys!
3PVP-E90B - Elbow
Thanks guys!
