I have been shopping for wood inserts to fit my prefab fireplace - my most limiting factor for fit is the height of my existing firebox - it is right at 20.75 inches iwth a depth of 18". I got pricing on a new Regency i2400 and was shocked with a $4,500 installed price. I am guessing the stove is $2,000 - and my 6" 35 foot flew insert and associated parts would come in around $1,000 or less - hence their installation charges are $1,500 for a 6 hour job?
What am I missing here?
Since I don't want to spend $4,500 for this setup, I have been searching for a used wood burning insert and have come across a LOPI Model THE ANSWER-95 which I believe can be used as an insert if Ibuy a blower and surround. Is this correct?
I have also found a 20 foot SS 6" flex flue liner that is lightly used for only $150. Can I use a connector to piece together another 15 foot SS Flex flue liner to meet my need for $35'? I would then use a proper foil insulation wrap for the entire flue liner and install with proper connector to the stove and a new flue cap,etc. on the top end.
Your advise is greatly appreciated.
I am guessing I need to budget for one continuous 35' flue liner and get a professional installer to make all this happen.
Thanks!
Thanks!
