Questions of VC Vigilant install
Horvik
16
Chicago
Hello;
Am new to this so thought I would get my questions out here.
I am installing this unit diagonally with rear and bottom heat shields 24" or so inches from the wall and combustible surfaces , more than the 18" which VC states. Is it a problem that there are many windows in this area or no? Also have a concrete slab with tile on top. Am installing 2100 F three layer stainless pipe.
Thanks
Welcome. So far that sounds ok. How close are the windows? Can you post a picture of the location?
Here's a picture of the corner . I am in the process of setting up the chimney at this time.
  • Questions of VC Vigilant install
As long as you have proper clearances to all of the trim it shouldn't matter. And if you haven't gotten it yet i suggest going with insulated double wall rather than triple wall.
