I have this fireplace in my house that I have never used.
From what I have found in the ID tag inside, it is a Majestic model MHC36 and built between Aug 1980 and Nov 1985, as found in the Majestic Wood Firewood Index found here.
I have also found the installation manual, but no owner's manual.
There is a gas line in the fireplace and I am curious if this is a fireplace to be used to burn wood, to use with gas fireplace logs, or do I have the flexibility to use either one.
Questions:
If this can be used for burning wood, is the gas line used to help light the firewood?
If this is only for gas logs or I have the flexibility as I mentioned before, which types of gas logs should I use?
I have attached some photos at the end of this post. In the last photo, the dark looking stuff is something that dried at the back of the fireplace. It is not a leak or bit of moisture.
Thank you in advance for any advice or suggestions you guys can provide.
![Questions about Majestic from Newbie Questions about Majestic from Newbie](https://www.hearth.com/talk/data/attachments/290/290349-67c8ae1346d7e83664b423ca95f3d6ca.jpg)
Questions:
![Questions about Majestic from Newbie Questions about Majestic from Newbie](https://www.hearth.com/talk/data/attachments/290/290344-71f62320022038f187c12af4ad4a6209.jpg)
![Questions about Majestic from Newbie Questions about Majestic from Newbie](https://www.hearth.com/talk/data/attachments/290/290346-9dba91a6f072dc4df503fde20c2a1446.jpg)
![Questions about Majestic from Newbie Questions about Majestic from Newbie](https://www.hearth.com/talk/data/attachments/290/290347-04eaab0f74c58f7931da9ec9ac690b3b.jpg)
![Questions about Majestic from Newbie Questions about Majestic from Newbie](https://www.hearth.com/talk/data/attachments/290/290348-1ebf9d6b8695a4ab0d3180cb23e0f779.jpg)
