Finally close to purchasing a stove. Was set to get a Jotul Castine but my wife definitely likes the look of the Heritage soapstone stove, and it would seem to fit our (wants) and NEEDS well. Our details:
1. Connecting stove to an inside masonry fireplace that I will fully line. Flue goes through a second story attic so draft should
be fine(draft was very good with an old Fireview insert directly vented into the fireplace)
2. Heating about 700 sq feet and need at least 25000 BTU based on calculations I've done online. Have another 500 sq ft
down hall and into two bedrooms that may get some heat also.
3. Want to use the stove as primary heat and have oil furnace as backup - hopefully way back!
I understand soapstone will take longer to heat up and cool down. No problem as we plan to keep a fire going most of the time. BeGreen mentioned, in another post, about just taking the chill off in our cool Northwest Fall and Spring. I assume I can regulate the temp enough to not cook us out on these damp 50 degree days. I've read a bunch on this website, and elsewhere but wonder if might be missing anything when considering the Heritage and soapstone in general
ie. location of stove relative to fireplace opening,
would rear heatshield be good addition to direct more heat to the front
would a hearth surround be a good way to get the most out into the rooms
or best to use it first before those options two options,
does wood need to be more seasoned for soapstone,
ash pan concerns,
how long will it really produce heat/warmth -
all the basic questions and perhaps those I haven't thought of yet!
ash pan concerns,
