Questions about a new (to me) fireplace insert
mouserusker
2
I recently purchased a house that has a Quadra-Fire woodburning fireplace insert. I am interested in using it as a primary source of heat for my home. I was wondering if anyone could help me identify the insert, since I have no paperwork or owner's manual. Also, I am a little concerned about the condition of the firebrick. It also seems that there are some brackets on the underside of the baffle... is there a firebrick or something else missing? Will I damage the insert or my home by using the insert in it's current condition?
This forum seems to be a wealth of information, and I look forward to your replies!
[Hearth.com] Questions about a new (to me) fireplace insert
[/IMG]
[/IMG]
The firebrick can be replaced cheaply enough, although it looks like you will have to get some of them cut to fit. I would pull the perforated shrouds on either side of the firebox & see if you can find a rating plate with a model #. If you can, then you can search the Quadrafire web site to see if there's a manual available, for that model #. The manual & stove schematic should tell you what is supported by those brackets. Looks like there should be a baffle in the brackets & obove the rear secondary tube, but I could be mistaken...
I've read (on Hearth.com) that if you fo to a Stone place the firebrick will be cheaper than if you go to a stove shop...
Oh, yeah. A masonry supply store or a block company will have split brick for less than $2 each. A hearth shop will probably step on that by another buck.
It looks like an older version of the 31/3100 series but I cannot find a manual that matches. The nameplate should be just behind the surround on the side of the stove. It would be easier to get information with the exact model number...
KaptJaq
