Hi,
First post from a long time lurker. I've got a long series of questions here about a proposed multi-home heating system. I've tried to read as much as I could on the forums and elsewhere before posting so I'm hoping not too many questions will be of the completely obvious variety but I won't make any promises.
First a short description of the context for this half formed plan of mine: A communal farm in northern Nova Scotia with seriously cold and long winters (trees are just budding out now.) Lots of hard wood available 70-80$ / chord in eight foot lengths. We want to heat
1. an old farm house with an existing system of cast radiators which are unused at the moment (we have been burning 10 chords per year in a large pacific energy and heating only half the house. (An energy assessment we had done pegged annual energy use for space heating and dhw at 270 million btu.)
2. A semi tight 900 sq. ft. bungalow and its unattached but insulated garage. (Based on present oil use space heating and dhw require about 80 million btu.)
3. A starting green house in the shoulder seasons
4. A proposed 1200 sq. foot straw-bale house
5. Perhaps some shop space etc.
The farm house and bungalow are 250 ft apart with a barn which seems appropriate for the boiler room standing roughly in the middle of the two. We would like the system to operate as a mini utility with the capability to meter the energy usage of each end user. I also have an interest in being able to plot system data in a similar way to nofossil as a means to being able to optimize the system performance and just for nerdy fun (although I must admit to being less competent nerd than I'd like).
I've tried to organize the following questions in a rational manner so if that if this post seems absurdly long you fire masters out there can bite off a chunk of your liking.
1. Boiler Sizing
I think I have a handle on the method of calculating peak load using degree days thanks to a post. Once I've got this number is there anything I should know` specific to wood boilers
a. what about twinning two smaller boilers for more efficient burns in shoulder seasons and for a more robust system?
2. Heat loss through piping
One of the major disadvantages I can think of for a multi-house system. Things I think I'd need to know to make calculations would be
a. Pipe diameter needed to service a house
b. normal flow rates
So far the best product i can find is pex flex which is distributed by Urecon in North America. Any other good options people know of? This stuff is very expensive (11$ per foot) and would make up a substantial part of the cost of our system offsetting a healthy chunk of the savings we'd get from buying one larger boiler.
c. I'm also curious about a means to purge stranded hot water from the end of a pumping cycle. Is this practical and or necessary?
3. Storage
I know there is a lot in the forum already about storage design and construction and I haven't read it yet so I skip asking about that.
a. What are the possible advantages / disadvantages to having the storage in close proximity to the boiler or distributed at each end user?
b. Is there an ideal ratio between peak demand and storage size or storage size and something else that I should know about?
4. Controller
A "homebrew controller" a la nofossil seems sadly out of reach for my level of technical expertise. Other options I have come across include a standard plc, a tekmar type controller, some more analog system which I don't have the vocabulary to express or whatever comes with the boiler. Are there other options? Considering the following desires which would be best?
a. prioritize radiator heated zones and dhw over radiant areas
b. prioritize certain users over others at peak demand if there is insufficient heating capacity
c. Some sort of alarm indicating a firing is required
d. minimize the number of "pumping cycles" between boiler and users.
e. enable eventual incorporation of solar hot water
5. Eco vs Garn type
I have seen both vouched for on this forum as quality products. Any opinions for this particular application?
6. Professional Help
I'd like to do as much as possible of the system design and construction. (with the help of the fine minds on this forum of course). On the other hand i don't want to do anything dangerous or needlessly wasteful of time or money. Here are some categories I came up with yeah or nay to DIY would be much appreciated. I have done a fair amount of plumbing and wiring around the farm but nothing close to this scale.
a. plumbing diagram, system design
b. installation of boiler
c. installation of storage
d. integration of controller
e. design of ladder logic if using a plc (i have a little bit of programming experience)
f. installation of zones and heat sources in house
f. others??????
7. Here are some advantages/disadvantages to multi-house system i have come up with. Any additions or subtractions to this list or or opinions as to wether the basic idea holds water would be much appreciated.
Adv
a. larger boiler cheaper per btu
b. reduces need for back up heat/ other will be stoking some of the time
c. presuming some surplus capacity makes heating new structures simple
d. enables those who aren't normally able to use wood heat like the elderly or disabled (considerations for future projects of the farm)
e. one controller
Dis
a. insulated piping is expensive (pex flex 11$/foot)
b. increased complexity
c. heat loss to ground
d.
Thanks for reading what feels like a long winded and demanding post. In our part of the world wood just makes a lot of sense and who can complain about lots of DHW (certainly not the wife). With heating oil prices headed the direction they are Biomass energy seems like the way of the future and I'd like to think of this project as a pilot for mini district energy systems. Imagine a boiler a boiler a the center of every block![Smile :) :)](/talk/styles/default/xenforo/smileys/grin.gif)
Augie
1. Boiler Sizing
3. Storage
4. Controller
5. Eco vs Garn type
f. others??????
Adv
e. one controller
Dis
d.
Augie
