Hi,
I'm hoping someone can help me. We're considering buying a house that has a freestanding woodburning stove sitting on a brick base with a brick wall behind it. We don't really like the brick, plus with 2 small children are concerned about safety.
My question is, how hard and labor-intensive & expensive would it be to remove the brick and create a stone hearth there instead? Then maybe put a woodstove insert with a heatilator in it. I'm thinking it would use the same tube thing that's currently there for the stove, and no chimney would need to be built since it's just the look of the fireplace with a stone hearth rather than an actual working woodburning fireplace.
Does anyone have any advice about this you'd be willing to share? Also, how well do the woodstoves heat? The house has electric heat and I heard that was really expensive. I've always had gas heat and currently have a gas fireplace (but grew up w/ a real one) so we're totally clueless on electric heat & woodstoves.
Is thinking about converting for safety and aesthetic reasons even an issue for other people? Is it cost-prohibitive? We're in Maryland if that helps.
Thanks for any and all advice you can give!
