Hello, new to the forum with a few questions. I am in doing some landscaping around our home and needed to install a sump drain to the outside of the house from a utility area in the basement. This required digging a 4-5ft deep x 20ft trench under a covered porch that only had a foot and a half ground clearance. This was such a huge joy that I don't think I handle this much fun again. So while its opened up I would like to run anything needed for a future boiler install. My question is if you were to have the ground opened up and have the ability to pre run what ever your hearts content to a boiler system, what would it be?
Specifics on the house and system:
Our home has three in floor zones. One is the garage which I really don't think I would heat but it may be an option. I have an electric hot water heater I would run an side arm exchanger off of and then also into a forced air system. The house is about 4000sq/ft. The plan would be for a gasification boiler system placed in it a pole barn about 150ft away. I would have a 1000 or so gal heat sink. I have a buddy who spray foams and would go that route for the run to the barn/heat source.
I talked to two local installers (NW WI) and both say only one run from house to barn/heat source. One said to run a water line to have fresh water access at the storage and stove. Both said no additional wiring other than power. I thought there has to be some other low voltage stuff to run? I am kind of a geek with stuff like this so I would like to know what else should be ran? Temp monitoring? Networking?
What I am working on right now:
- One run of Thermopex from the basement into the trench and ran 20ft under the porch (4ft deep in ground) and it will terminate about 5ft into the yard for future use. I can't get my buddy to spray foam a short run like this right now he is busy with good paying work. I am going to run to Menards and see if they have a 5” flexible tubing of some sort that I could run over the Thermopex and spray canned foam to add a little insulation where the Thermopex is exposed to air as it exits the house and enters the ground under the porch. Not sure if this is over kill. I did see a thread on the forum here where the Thermopex didn't melt snow it was exposed to.
- One 3/4” pex water line inside a 3” PVC filled with canned spray foam into the ground 4 ft deep and from there the pex is unprotected and ran out to the same area in the yard.
- One 3” PVC empty for what ever I usually wish I did once I have sealed everything up.
- One 2” PVC conduit to run power to boiler.
Thanks for any input and suggestions. I will post a write up once I am finished for future newbies like me.
