how far of run is to far i need to run the line about 20 ft is that to far the stove is set in the basementand pipe into my chimmey which is in the center of the basement thanks john :question:
yellowpike said:how far of run is to far i need to run the line about 20 ft is that to far the stove is set in the basementand pipe into my chimmey which is in the center of the basement thanks john :question:
yellowpike said:An outside combustion air connection is mandatory for this unit to work properly. Make this
connection using a 1 7/8†I.D. metal pipe (steel, aluminum or copper; commonly found at
muffler or auto shops) and coupler. Be sure to secure the pipe to the unit with a clamp or
aluminum tape. The outside end should be covered (screened) to prevent any foreign matter
from entering the system. Try to keep the number of bends in the pipe to a minimum. NOTE:
If the total run of the connection exceeds 6’, use 3†metal pipe (and coupler) instead it dosn"t say anything on far is to far mo 25pdvc
